Hi
I'm using vee 9.32 running on .net4.5 framework.
I've got a library based on .net4.0 framework. Is it possible to import and use methods of .net 4.0 or .net4.5 library?
Since the application vee 9.3 is running on .net4.5 plattform, it's somehow expected, that also the assemblies could be referenced within vee programms.
In this forum I found (4 years old) :
Create own dotNet instruments driver use in VEE-.NET 4.0 W7P
Is there a roadmap, when .net4.0/4.5 assemblies will be supported by vee?
If there is no solution, I have to move the whole vee application to a pure .net4.5 project.
Regards
andreas_h
Edited by: andreas_h on Jan 29, 2014 12:31 AM
Edited by: andreas_h on Jan 29, 2014 12:44 AM
I'm sure that later versions will be on the roadmap but Agilent are giong to be internally focussed for the next year or so as they are cast off into their new company Keysight; I wouldn't expect VEE X ( mentioned over 2 years ago ) is unlikely to emerge any time soon in my estimation.
