Hello everyone.
I’m using an Agilent 4339 meter with Vee Pro software on a PC with Windows 7 operating system. When the run is completed I receive an error that says: “Vee Run Time Error”, “Error number: 700”.
Essentially it looks like the file path cannot be found. I’ve tried several paths but get the same message.
The software worked before when we were using Windows XP. The PC was recently installed with Windows 7 and now we’re getting these errors. Has anyone had a similar experience?
Thanks all!
Thanks all!
You have to bear in mind that Microsoft changes the file locations in every version of Windows, so trying to get examples to work for all combinations can be a challenge!
