I have a problem with the Coverage Analyst.
I am using the Coverage Analyst version 5.21p. The Coverage Analyst finishes the coverage report ok (html files), but i have a problem with the results shown in the report:
- Coverage Analyst shows that some devices (Resistors) do not have any test associated with them, so as, the html report-page of each device shows "Number of tests = 0".
But:
- Each one of these resistors have their own object file in the "analog" folder, and they are tested ok with the ICT.
- These resistors have the properties "placed" and "testable" in the file "board.o", and they are included in the "testorder" and "testplan" files.
So, the question is:
Why the Coverage Analyst does not show that these resistors are tested?, What can be wrong?
Thanks in advance for your help.
But:
May I know which category are the resistors found in the board file?
Are they under the RESISTOR category or in PIN LIBRARY?
Would you like to send us the test directory?
This will allow us to determine the reason for this.
Please send to adrian_cheong@agilent.com
Thanks ... adrian
