hi, i'm new here.
i have a couple of questions. i understand that N6705B comes with vary of configurations as a dc source and dvm, scope, battery simulator.
i need to build an ATE station for checking IC circuits (2, 3 units in parallel). test are: D/A inputs, outputs, battery drain simulation .
can i use this instrument for these tests or i need more modules as mux, data acquisition, relays?
The N6705B can only accept N6700 DC power modules. The measurements are all on its own outputs so it can measure the voltage and the current that it is sourcing.
There is one exception. The N6781A, N6782A, and N6784A SMU modules do have measure only modes where they can measure external voltages and currents. The N6781A is optimized for battery drain analysis so you might want to take a look at that model to see if it fits your needs.
Let me know if you have any other questions.
