All,
I have a Flex circuit made out of Polyimide (er =3.3 to 3.5), I want to confirm the impedance of single ended microstrip and differential even/odd mode traces using ADS2011 Layout. I have loaded the Gerber files into the tool, and I can setup multiple ports. My goal is to extract the single ended/diff impedance in the presence of a cross-hatched plane (not solid). The flex circuit is used in a dynamic environment, and it cannot be a solid plane reference as it will fatigue it, and eventually fail over time (cracked traces etc). I want to adjust the traces, and cross-hatch parameters to hit 90 ohms differential impedance, and 50 ohms single ended.
I will split the problem in two cases -- the differential and single ended. I want to setup a case for the differential, and extract the impedance of the traces for even and odd mode. I am sure this is a piece of cake in ADS, I just don't know how to set it up. I know I can convert the impedance Z11 = 50*(1+S(1,1))/(1-S(1,1)). From here how do I get odd and even mode? How do I parametrize the cross hatch so I can vary the some parameters and look at the impedance changes?
I would really appreciate it any help. I have dug up my old books and I recapped the impedance for even=Z11/2 odd=2*Z11. However, I just need to know how many ports I need to put on my traces. For the differential case, I imagine this is a two port measurement, but what about the ground reference? I would put the following ports P1,P2 to diff pair one end. P3,P4 to the other end, what about ground? Is it just P5? Do I then export this to schematic, and add ground since I can't add ground in Layout?
Any help would be greatly appreciated. This is a classical case I have gotten around experimentally and through FCC testing, but I don't have a simulation model to predict this without iterating the flex.
Thanks
rjrodrig
Thanks
rjrodrig
Maybe this would be useful: http://edocs.soco.agilent.com/display/eesofkcads/A+convenient+way+to+calculate+characteristic+impedances+Z0+and+Zdiff+from+microstrip+and+stripline+transmission+line+in+ADS
