Hi:
On a DSO/MSO-X 3024A/3034A if I press "Serial" then turn on the "serial 1" (S1) bus display, then turn it back off again, the next time I power the scope, the S1 bus display is back! Even if I turn S1 off, turn S2 on, power cycle, S1 is back! There seems to be no way to get rid of it.
Do you experience this same bug?
After some convoluted sequence of turning serial busses on/off, and power cycling, I've managed to get S1 to disappear without a factory reset. Maybe it will return next time?
Also, the "Serial" button LED doesn't light up when a serial bus is displayed.
Clearly there are some bugs here. I would expect that this has been well known, and is promised to be fixed in the next firmware, right?
Al
