Hello all!
Im using a N6762A and i wrote a VEE code to performs Current - voltages caracteristic. I tested a sample of metal semiconductor diode but it do not give the same curve than the same one published by some other author. The current values are too diferent from my own. I dont know if its my program whoo is wrong or other thing. I dont know if some one cant have a program for I-V caracteristic for me. O r attached my program for some one who can try it and see if its correct or not.
One thing that I do not really see is a wait between turning the output on and measuring the current. You might want to put a short delay there to allow the output to settle before you take a measurement. Give that a try and see if it works.
