By default and after switch on, the analyser N9320B is in Standby mode. Is it possible to make it boots up directly after switch on, without pushing on the power switch ?
Thanks.
M. Chenal
Thanks.
M. Chenal
Please order the N9320BK-C30 for the customized power on function.
The option C30 is a customized motherboard. With this motherboard, the N9320B will boot up without pressing the power switch on the front panel. The switch on rear panel become the unique switch.
With this option, the N9320B will keep running even if you press the power switch on front panel for a long time. FYI. If user wants to turn off the unit, please turn off the power switch on rear panel on just cut off the power.
Regards
Simon
