Dear All,
I'd like to know whether is possible to make different FEM simulations of the same geometry keeping the same geometry mesh but changing material properties. I know it is possible by using 'reuse' when you edit the simulation setup but it does not work when you make a change on the material properties that you have defined previously. I'd like to solve my geometry with different material property values but with the same meshing so EMPro should not re-mesh in each simulation. Hope understandable.
Is there any option to make different simulations in this way?.
Pablo.
Pablo.
