I saved a Trace to a file on the MXE N9038A. The resulting file has a .trace extension. Rather than a text file of the trace data, it appears to be a binary format. I have not been able to find a format specification, or a program to convert it.
Can anyone explain how to open and use a ".trace" file?
If you want to save trace data to use it elsewhere you need to Export it. You can do this by pressing *Save*, *Data (Export)*, select what you want to save, *Save As...* This will save the traces in a .csv format which can be used by many different PC programs.
Best regards,
Mike
