Hi all,
I'm working on repairing UPS's and AC motor controllers.
I need a high voltage differential probe and I can only get a Pintek DP-50.(http://www.pintek.com.tw/files/pintek/DP-MANUAL.pdf). My question is whether it will work properly with my DSOX3014A? .
Sorry for my bad English.
Thanks in advance
Best regards from Argentina
Marcos.
Thanks in advance
Marcos.
Your mileage may vary.
Al
