I created a simple testbench with two ports (library: analogLib (cadence) ; cell: port) connected through a series resistor. I set a 100mV amplitude signal at RF_freq at one of the ports and tried to run LSSP. After configuring according to the manual and running the simulation I get the following error:
Error: LSSP: At least one active port should be defined to run LSSP analysis. [119.1115]
Is this an error anyone else has seen and managed to solve? I've tried psin and goldengateLib RFPWS as my ports as well, with appropriate parameters.
Thanks.
Thanks.
