The UART serial trigger on the 3000X series allows you to trigger on a DATA value but does anyone know if it is possible to trigger on a sequence of DATA values?
The 3000X family does not have the capability of triggering on a sequence of data values. Other, more capable, scopes, such as the 9000 family, do have the capability of triggering on a sequence of data values.
Al
Al
