I generate an LTE signal with agilent signal studio, I save the wavelength I get into to scp format, but when I try to recall it on VSA i didn't get the same parameters. for example the bandwith is not the same and the center frequency as well.
How to recall a signal with the same parameters as signal studio?
What version of VSA are you using?
Can you provide your .scp file?
