Does anyone know how a problem with the 54503A can be repaired? see attached files for a printout of the self test.
the load failures are
failed Protected Non-Volatile Ram
failed analog trigger
Failed D/A converter
failed A/D converter
A/D; GAIN; OFFSET; HYSTERESIS; TRIGGER; DELAY; are corrupted in all 4 channels,
TIME NULL is corrupted in channels 2,3 & 4
and the LOGIC TRIGGER is corrupted in the first channel?
I am considering purchasing the damaged scope, and I'm wondering if it is fixable, by myself if at all possible, and would like an indication as to what I can expect?.
