Setting Desired Cursor Point Using SCPI code in Agilent VEE PRO 9.3
Question asked by leong8898 on Oct 8, 2013
Latest reply on Oct 10, 2013 by leong8898
Hi all, I am a degree student and currently doing my last semester project which due with Agilent VEE and SCPI code. I am trying to control the non Agilent instrument in my college' s laboratory which is DS 1102E Digital Oscilliscope and commands using SCPI (Standard Commands for Programmable Instruments) code in Agilent VEE PRO 9.3.
All the program flow is done in Agilent VEE software by using SCPI code.
Problems:
1) How can I fix the cursor point with track mode at my desired point on the oscilloscope screen using SCPI commands?
    Attachment is the desired cursor point that I wish to set.
2) How can I make sure the display waveform always stays at a fixed point using SCPI commands?
3) Can I directly set the display position for the waveform using SCPI commands?
Above are my encountered problems. Sincerely hope for the suggestion of SCPI coding or ideal for solving those problems.
Thank You for the reply.
