vrf math operation in 2D array
Question asked by VRFuser on Oct 17, 2006
Use the following 2 lines in a formula box with a as the input:
a[*,0]=a[*,0]/1e6;
a
Divide the first column by 1e6, then output the entire array as the result.
Hope this helps,
Mike
Michael N. Asbery                (202)404-3014, DSN 754
US Naval Research Laboratory      fax (202)404-7661
Code 5733.20                    michael.asbery@nrl.navy.mil
4555 Overlook Ave SW
Washington DC 20375
  _____
From: Thomas, Pete (GE Healthcare) [mailto:Peter.Thomas@med.ge.com]
Sent: Tuesday, October 17, 2006 3:17 PM
To: VRF
Subject: [vrf] math operation in 2D array
Hello all,
             Is there a command that I’m missing that I can use to only perform on a single column in a 2D array and still keep the 2D array intact.  For example I have a 2D array with 140 rows and 2 columns,  I would like to only change the 1st column and divide it by 1E6.  When using the command ary[*,0]/1E6 the result is a 1D array.  I would like to keep the 2nd column of data intact.  Was wondering is there is a simple command vs. re-creating the 2D array.
Pete Thomas
Senior Test Engineer
MR Test Engineering
• Phone: 262.521.6758
• Mobile: 262.993.0154
• Pager: NONE
• e-mail: HYPERLINK "mailto:Peter.Thomas@med.ge.com"Peter.Thomas@med.ge.com
GE Healthcare
You are currently subscribed to vrf as: michael.asbery@nrl.navy.mil
