I have been working on troubleshooting a problem with G.729 encoded Voice stream. The problem is that I commonly see the problem between remote machines that do not have NA capabilities. I can load winPCAP (windows) or TCPdump (Linux) to capture the network traffic, but I have not been able to import the resultant capture files into Net Analyzer, it says "Created by unknown application" and reports "No Data is selected for the open"
I can open the file in Ethereal, but Ethereal cannot interpret G.729. I can use Ethereal to save the capture in Sniffer (.enc) format, but it still does not import.
Has anyone ever been able to import a "standard" TCPdump or winPCAP capture file into NA for analysis?
In case you are interested, I have posted a copy of the sniff file at this location:
http://tobyfoss.com/SIP/bob1.enc
It is about 600Kb capture file in "plain" capture format. I have tried to use Ethereal to convert it to a sniffer 1.1 and 2.0 windows format, but NA still cannot read it.
Thanks in advance for any assistance.
Toby
Toby
I believe that you question is a bit out of the realm of this particular forum which is geared toward scalar and vector network analyzers. You might take a look at the J6839A Network Analyzer Software. We offer a free version at the link below.
I would recommend contacting your local Agilent Contact Center. You can make contact by using any of the methods listed on http://www.agilent.com/find/contactus. This forum discusses the usage of Scalar and Vector Network Analyzers (a type of stimulus/response measurement equipment). Check out http://www.agilent.com/find/na for more information about these types of network analyzers.
Agilent Network Analyzer Software (for IP networks):
Free Version of Agilent Network Analyzer Software
