When I use the iDriverResults = Ag34980a_init(caAddress, FALSE, FALSE, &gul34980A); command to initialize I get an error -21474836648 (Hex 80000000). ibsta reports 8000, but iberr reports 0. No other driver command work until this one works.
NI-MAX is able to initialize and get the ID from the *IDN? command. If I write the low level ibdev command and then do the low level ibwrt/ibrd command I can initialize the instrument and get the ID.
The driver seems to always return 80000000.
Is 1.5.3.0 the newest driver for the 34980? Why would the driver not be working. I would hate to have to write a driver myself.
