Whenever I start an optimization in Genesys, starting scattering parameter traces (StartOpt traces) are added to graphs. As the optimization proceeds, the original traces update as component values change. I'd like to easily delete the StartOpt traces once the optimization finishes. Short of copying the graph, deleting it, and then pasting it back into the file tree, there doesn't seem to be any easy way to delete the StartOpt traces. How do I easily delete the StartOpt traces? In earlier versions of Genesys, I could open a graph's property window and remove the StartOpt traces from the list of measurements. I can no longer do that.
Thank you, Jeff
Thank you, Jeff
