Hi
I am trying to implement an automatic test program with EXA Signal Analyser N9010A in matlab 2012b 64bit version.
On Agilent page,
http://www.home.agilent.com/agilent/software.jspx?cc=GB&lc=eng&nid=-33932.710350.02&id=2204527
Is window 8, 64 bits version is not compatible with this IVI and matlab instrument driver?
If not, is there a way to make it work?
Thanks in advance
with best regards
Adam
Edited by: Adamzaw on Jan 11, 2014 3:41 AM
Edited by: Adamzaw on Jan 11, 2014 3:46 AM
On Agilent page,
Thanks in advance
with best regards
Adam
The newer IVI-Com / IVI-C / MATLAB drivers for X-Series instruments that are posted to www.agilent.com/find/sa-ivi that support Windows 7 64 bit should all work with Windows 8. These drivers were all created with the Pacific Mindworks Nimbus 2 tool.
You will need Agilent IO Suite 16.3 (released Oct 2012) or later if using Windows 8.
Regards -
