I would like to set the WINDOWS (property) of the VEE Panel to be Set to Back (similar to the way we arrange the graphic in WORD or Powerpoint) and Always stay at the Center of the display.
However, there is not section of setting for this parameter in the VEE panel's property.
If you have any example program , do feel free to add in the reply.
I have attached the screen shot to show the location of the VEE Panel that always pop up, I need it to defuat to be in the RED rectangle when started.
I do appriciate you assistant on this.
I have worked on this to complete the project for a few months, this is the last stage of the test program.
Thanks
Best regards
Shyboy
Thanks
Best regards
Shyboy
