I'm designing a GSG coplanar circuit. I have pads at the input and output for ground-signal-ground connections. I also have pads for biasing in a power-ground-power configuration. And I also have internal ports for connections to devices such as FETs and capacitors for an EM co-simulation.
I've used ADS 2009 a little bit in the past but I'm unsure how to setup ports in the new ADS 2013 for this kind of coplanar design. If someone could explain how to setup and calibrate these 3 connection types (GSG, PGP and internal) I would be very grateful.
edit: I should mention that I'm using microwave momentum for the simulation.
Edited by: kippodan on Dec 1, 2013 7:59 PM
