sliding load and PNA
Question asked by lhiga on Feb 17, 2007
Latest reply on Feb 26, 2007 by daveb
The specifications for the sliding load states a VSWR spec accross the frequency spectrum and a minimum wavelength travel at a low end frequency.  Is it an ok assumption to assume that the second specification means that when viewing this from a polar plot that a minimum 1/2 wavelength means that the polar plot should rotate 180 degrees minimum as the slide is moved from one extreme to the other?
