I have an 81250 that was working fine until recently. Now, when I open the User Interface, I get error messages at the startup that say "Unable to create logfile" and "Can't write to log file". Then, after I select a system, if I try to load a saved setting file, I get an error that says "Error 21516 - Failure in the data base - can not store a data base object".
I've cycled power on the chassis and rebooted the computer.
I've never encountered this before on any system I've used. Anyone have any suggestions on what might be wrong?
Mike
Edited by: Holmes IV on Apr 30, 2014 4:56 PM
Mike
which version of the ParBERT 81250 do you use?
The newest one is 6.33, available on A.com.
Thanks and regards,
your ParBERT support team
