Just a quicky in case some one else has come across this
Have been happily running VEE7 for years on this machine an evaluation copy of VEE9.2 worked fine also.
But a brand new copy of VEE 9.3 fails to run following install ?
Description:
Stopped working
Problem signature:
Problem Event Name: CLR20r3
Problem Signature 01: vee.exe
Problem Signature 02: 9.32.17704.1
Problem Signature 03: 5226d654
Problem Signature 04: vee
Problem Signature 05: 9.3.0.0
Problem Signature 06: 5226d654
Problem Signature 07: 3
Problem Signature 08: d1
Problem Signature 09: System.DllNotFoundException
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 2057
Description:
Stopped working
Problem signature:
Locale ID: 2057
Then re installed the dot net 3.5 and then the typical install and it now works !
