I will explain my problem,
I have an Agilent DSO90604A and I would like to measure the interval time (or also says interarrival time) between each perturbation. So I can use the measurement "Burst Interval" but this fonction measures only one interval time. This is the problem.
With my program Iwould measure each interarrival time of all pertubations (from device or network of home) for a duration of 1 second for example. Then the values should be stored (with Microsoft Excel).
Do you have solutions for this problem, please?
Sorry for my English, I am French.
Thank you.
Edited by: Mike45 on Jul 31, 2013 8:27 AM
Thank you.
Une image vaut mille mots!
Al
Je ne parle pas français :-)
