In the multiTone interface for PSG 8267D, I notice that "DONE" need to be pressed before the phase noise and its seed can be set to Random. However, I could not find the SCPI for this "DONE" command in the SCPI reference manual.
About the scpi command which is similar to DONE, it's not required since if you are sending the SCPI from the Initialized Menu softkeys, it will be already completed.
Eg. send:- ::RADio:MTONe:ARB:SETup:TABLe:PHASe:INITialize Rand
The comamnd would had taken place. You can try it out.
Petrina Yong
