Saving PNG images of display are now black (or very close to black) instead of color as they used to be.
Images had previously been saved with correct colors, graticule inverted as in Image1 attached.
Images are now captured with very dark traces as in Image2.
The only thing that may be related to this change is that the scope went out for calibartion in July. Data prior to that was correct and latest data is dark.
This is true if saving from the front panel of the scope OR from program with command ":DISP:DATA? PNG,SCR,COL".
Anyone know why this may happen or how to correct it?
This was a result of the INTENSITY being turned way down. Surprised the screen looked so good with the intensity close to 0.
Turning it up fixed the PNG.
