I'm trying to record a signal with the VSA software but I noticed that the noise floor for the VSA is 20 dB higher than the one I see on the Spectrum itself. I use the same parameters on both setup. How can we explain or reduce the difference between both reading.
The record didn't give a good signal to replay, but if I'm able to reduce the noise that will help me.
Thanks for support,
Thanks for support,
Voila
