I am using a set of DSOX3SGM, Segmented Memory Application for 3000 X - Series Oscilloscopes remotely operated by a LabWindows based DAQ system. Since transfer of data from all the oscilloscopes through TCP/IP connection takes long time, I want to save the waveforms to the respective USB drives I put on the scopes. I can do it manually. However, I want to do it through remote application in my program. I used following syntaxes:
:SAVE:WAVeform:FORMat ASCiixy
:SAVE:WAVeform:LENGth max
:SAVE:WAVeform:SEGMented ALL
:SAVE:WAVeform:STARt \\usb\test.csv
My first three commands executed successfully, but the fourth one never working.
It says INST Error -101, unrecognized character.
I am using C coding, I even printf the command which I sent, all different options, but no success.
Please help me, I know I am doing some silly mistake. Thank you very much for your help.
Command Syntax :SAVE:WAVeform[:STARt] [
Try :SAVE:WAVeform:STARt "\\usb\test.csv"
Al
