I am trying to perform a ripple measurement with a 5230A network. I checked the help file and it was not even mentioned the ripple word. How do you do a ripple measurement with the 5230A?
Depends upon what you want to do, but you can get the peak to peak ripple by using the trace statistics function. You can limit the trace statistics over a narrow range for a particular trace, and then look at the peak-to-peak value. Look up "trace statistics" in the PNA help file.
