PNA-X MMEMory:STORe:TRACe:FORMat:SNP DB
Question asked by jeffturp on Jul 12, 2013
Latest reply on Aug 7, 2013 by daras
When saving s-parameters and noise parameters with command (sense2:noise:snp:save "C:/Program Files/Agilent/Network Analyzer/Documents/MyNoiseParams.s2p", "NoiseParameter") the output file for the s-parameters portion is always in Linear Magnitude / degrees format. I would like DB - Log Magnitude / degrees format. Even after executing the above FORMat command the results are still in Linear Mag format.
The interesting part is when I view the Save Data As window the Format pull-down menu does change after executing MMEMory:STORe:TRACe:FORMat:SNP DB. This proves to me the command is partially doing it's task.
