I have attached a 532XX Counter Screen Capture .png LabVIEW example that uses the Command Expert LabVIEW addon.
To run:
1. Install Command Expert 1.2 (free) from here: www.agilent.com/find/commandexpert 2. Open the attached VI. 3. Place in a valid GPIB address found by Agilent Connection Expert in the address box. (Ex: GPIB0::19::INSTR) 4. Place in a valid writable file pathway and file name for the .png file. 5. Run the program.
This example uses the HCOPy:SDUMp:DATA:FORMat PNG and HCOPy:SDUMp:DATA? command.
I saved/opened the project for LabVIEW 8.2. This should open in any later 8.X version. Please note this example will need to have Command Expert installed.
To run:
5. Run the program.
Connectivity
