I wish to remotely capture and save three channels on the oscilloscope (Infinnium 9000 series) at the same time . What is the best way/ commands to capture and save multiple channels on the oscilloscope?
I'm not sure how the scope saves all channels at once. Is there a separate buffer for each channel or is there just one buffer but the scope somehow determines which data is from which channel? I am trying to implement the same thing in my code as selecting the options on the GUI "multipurpose on trigger" and "save all waveforms".
Thanks alot for any help in advance.
- If 3 channels are turned on, and you trigger the scope, 3 channels get captured.
- If you save channel 1, then channel 2, then channel 3, they will all have the same timestamps, relative to the trigger.
So it's really no different than capturing 1 channel, just 3 times as much data to save.
Al
