Hi
I am able to run typical circuit simulation from command line in ADS (with hpeesofsim command). Is there a similar way to run momentum simulation from command line too? I intend to:
1- setup my simulation (do the layout, setup the substrate, ....) in GUI
2- copy the entire workspace directory to another university server with SSH
3- execute simulation from command line
4- copy back the results to the original server for further investigation
http://edocs.soco.agilent.com/display/eesofkcads/Run+a+Momentum+simulation+from+command+line
