we bought the N9322C Spectrum Analyzer with the TG7 and RM7 and want to use it for Reflection Measurements.
I have a few questions regarding the Labview Driver.
1.
If i made a reflection measurement i can read the graph (after correcting bugs in the driver)
with my Labview Software.
But i also need the Peak and Valley Values for Frequency, Return Loss and VSWR,
which are display at the bottom of the display.
+How can i read this values with Labview?+
2.
Before using the Reflection Measurement it is necessary to calibrate the spectrum
analyzer for the needed frequency span.
+Is it possible to start the Calibrate Funtion with Labview?+
Thanks in advance for your help.
1.
2.
In the Labview driver are a few bugs and not every function is impemented.
But i have one more problem.
+How can i start the Calibrate funtion in Reflection Measurement Mode with a SCPI command?+
The Key Access i need in Reflection Measurement is
*Freq > Calibrate*
I can`t find a command for this function in the N9322C Programmes Guide.
