Hello, everyone.
I have a problem about handling Agilent DMM Connectivity Utility. Please help :(
The situation is...
I'm using 34401A Multimeter and it's well connected to PC through 34398A RS-232 Cable using USB to Serial Converter.
Baud Rate : 300
Stop Bit : 1
Data Size : 8
Parity : None
Flow Control : None
SRQ line : RI (default, I dun know exactly.)
Software works as you can see in the attached file named 'untitled.png'.
And also does fine at first when I click 'start to acquisition'.
But soon (after few secs) it stopped and says,
"The operation failed to complete within the specified timeout period." (you can see 'untiled1.png')
I don't know why. Any idea? Plz?
The situation is...
Baud Rate : 300
Stop Bit : 1
Data Size : 8
Parity : None
Flow Control : None
