I´m programming with Labview a MSOX3034A scope and I'm not able to find a way to configure a TCP202A with current drivers. Has someone face same situation?
Beforehand, thank you for your comments.
Regards!
Regards!
First, does the probe work with the scope manually? If not, then it won't work programmatically.
Second, What do you mean by configure?
Third, why not just get an Agilent Current probe. Something like the 1147B or N2893A is fully supported by the Agilent scope, and except for Peak current, has better specs...
Al
