Dear All,
I want to remote the DSOX90000A scope to acquire waveform data automatic with trigger signal, and the software will be install on the scope(windows 7 system), so how to set the scope address in the VEE? thanks a lot
Alex
Alex
If so, then this is something you would not [normally] do with VEE. Instead, consult the instrument's user manual on how to set up the remote interface. With so many options on modern products, you'll probably first need to set which interface you want to use to control it ( GPIB, serial or whatever you intend using ) and then, if appropriate, set the address.
If you still have problems, let us know which communications interface you want to use and maybe someone will be able to guide you to the setting.
