Hey Everyone,
Relatively new to SCPI and Agilent's Command Expert software, but I was wondering if the X-series analyzer and LXI generator had a calibration technique built into their hardware?
I have written a program that automates all of my testing needs and am trying to implement a calibration process as is normally done before every measurement/test is ran and completed.
Thanks in advance!
Thanks in advance!
From the N9010A (EXA) perspective...
The N9010A (EXA) has a SCPI command to calibrate all its internal hardware. The SCPI command is “:CALibration:ALL”. This command is supported by Command Expert.
But if what you want is a SCPI command that uses the EXA and LXI Generator together to measure the cable loss between them, no such command exists in the EXA.
Regards -
