Skip navigation
Register
Home
Forums
Blogs
Help
My Links
My Bookmarks
My Questions
My Places
Log in
0
Search
Search
Search
Cancel
Error: You don't have JavaScript enabled. This tool uses JavaScript and much of it will not work correctly without it enabled. Please turn JavaScript back on and reload this page.
All Places
Discussion Forums
Network Analyzers
Questions
Log in
to create and rate content, and to follow, bookmark, and share content with other members.
Answered
Assumed Answered
Use Teechart activeX component in VEE
Question asked by
yjames_1
on Jul 13, 2006
Latest reply
on Jul 13, 2006 by yjames_1
Like
Show 0 Likes
0
Comment
2
Is there any sample code or application notes on how to use Teechart activeX component in VEE?
This content has been marked as final.
Show 2 comments
Name
Email Address
Website Address
Name
(Required)
Email Address
(Required, will not be published)
Website Address
odanzy
Jul 13, 2006 3:28 AM
Mark Correct
Correct Answer
I know that I haven't used this in VEE (today was my first time hearing about it). What type of chart do you want to produce?
You might also post this on the VEE Reflector (if you haven't already). You can sign up for the reflector at
http://www.agilent.com/find/vrf
yjames_1
Jul 13, 2006 6:14 PM
Mark Correct
Correct Answer
The chart i want to create is vertical radiation pattern of the antenna. The reason that i prefer to use Teechart is because it has more funtions to manage the chart for the operator.
You might also post this on the VEE Reflector (if you haven't already). You can sign up for the reflector at http://www.agilent.com/find/vrf.
