We currently obtain data from in-line measuring equipment using HP-VEE over an RS-232 port. The proposed in-line equipment upgrade uses OPC server-client software and ethernet communication.
Using a trial version of Agilent VEE PRO 9.2, my HP-VEE program, minus the data input section, works normally.
I need to find out if Agilent VEE can communicate with the upgraded equipment without having the equipment to do so.
Can Agilent VEE Pro 9.2 interface with an OPC server using the TCPIP option? If it can, what has to be done or what information is needed in order to do so? Thanks for your help.
David Dea
David Dea
-mk
