Hi all,
I am a new member to the VEE community and have only been programming for a little while now. When I try to open a VEE file saved a couple months back (no changes made since then), this message appears:
VEE Caution
Cannot execute file 'visa32.dll'
Could not load dynamically linked library
When 'OK' is pressed, another message appears to ask to add the drivers, followed by the first message. These two messages alternate for each line that device's driver is needed in the code, if I continue to press 'OK', eventually my program is opened. When I try to run the program, a message appears that says:
VEE Run Time Error
Invalid device encountered
Error number: 904
Object title: Parse Error
Object type: Unknown
Any suggestions? I sincerely appreciate your help. Thanks!
VEE Caution
VEE Run Time Error
Error number: 904
