Dear All,
Can someone enlighten me on the use of the above mentioned power sensors along with the measuring receiver 8902A?
I was going thru the manual of the HP8562A pertaining the frequency response measurement and i found a power sensor HP8485A being used with the HP8902A.
Can it be used?
I havent tried but if it can be used, can you share how the connection should be?
Now, we use the 11722A thermal sensor with 2 cables..one to the RF i/p and the other the sensor input..my question is if we use the 8485A , where should we connect it?
Can we use the 11730A cable to directly connect it to the sensor input?
Appreciate the help and suggestion.
Rgds
Ruben
Can it be used?
Rgds
Ruben
