Hello there,
after installing matlab R2009b I can't start my Matalb Skripts within VEE8, every time i get the matlab command window with the following error meessage:
Warning: Directory access failure: C:\Program Files\Agilent\VEE Pro 8.0\matlab\toolbox\runtime.
Warning: Directory access failure: C:\Program Files\Agilent\VEE Pro 8.0\matlab\work.
To get started, type one of these: helpwin, helpdesk, or demo.
For product information, visit http://www.mathworks.com.
??? Undefined function or variable 'set_param'.
Error in ==> C:\Program Files\Agilent\VEE Pro 8.0\matlab\toolbox\local\matlabrc.m
On line 131 ==>
before installing matlab R2009b, i was using Matlab 7.0.1 with the Signal Processing toolbox and i have never had such Problem, Unfortunately now I don't have the license for the Signal Processing toolbox (but if it is the only solution to make my Matlab Skripts work again, i could get it)
I have tried to register the built-in MATLAB Engine by going the directory (CD)<VEE_installation_dir>\MATLAB\bin\win32\ and executing the command "MATLAB.exe /regserver." but without any success ! I still have the same error!!!
If anyone can help with this I would really appreciate
On line 131 ==>
