I did not change anything in the preferences with code completion. What is the default setting?
But this would then only solve my speed-problem (not the flashing and error after reboot)
But good to know that there is also a problem,
Currently i cant test it here. Everything works now, and never touch a running system.
Jochen
_____
Von: Baranski, Detlef [mailto:Detlef.Baranski@pilkington.de]
Gesendet: Freitag, 12. September 2008 09:47
An: VRF
Betreff: AW: [vrf] Mathlab not displayed in preferences and very slow
Ah, i understand now…perhaps you do not deselect the auto Code completion feature in the preferences within the development environment ?
If you do so ( then matlab script do not have code completition and gets faster ), the V85 version should be as fast as 7.5 - otherwise it would be a shame
detlef
_____
Von: Gallmayer, Jochen [mailto:j.gallmayer@lxinstruments.com]
Gesendet: Donnerstag, 11. September 2008 18:30
An: Baranski, Detlef; VRF
I solved the problem by downgrading the Vee-Version from 8.5 to 7.52. Testexec is still 6.1.
Now everything works without problems
1. Testtime is half of the time bevore
2. VeeServiceManager works also after a reboot
3. MathLab runs extrem fast
So all problems are currently solved by not using the up-to-date VEE-version 8.5
_____
Gesendet: Donnerstag, 11. September 2008 11:00
An: Gallmayer, Jochen; VRF
Each time you use a matlab script via device/matlabscript menu, the matlab script engine is used automatically.
If it is used the first time within your vee program, then it needs a lot of time . but if it is used second or third time, it is much faster as it is available in the background.
Try to use the matlab samples in the example folder. Running them once it needs a lot of time, second and more it is quite fast.
If you want to integrate something in your proggy, just use a simple matlab script at the beginning- like the initialisation routine of your program.
detlef
_____
Gesendet: Donnerstag, 11. September 2008 10:21
Thanks for your detailled answer.
How do i start the mathlab-Engine? And, how can i see if the engine is running?
Currently i dont have a separate step. I just execute a mathlab-function (interpolate).
Perhaps this the problem.
_____
Gesendet: Donnerstag, 11. September 2008 09:22
An: VRF
You do have Matlab script together with VEE, not the real Matlab full version. In case that you own the full Matlab version, you will see this in this menu then.
There were some problems in the past with this parallel installation of Matlab and matlab script, so that there is this choice now since vee8.5
Please have a look in the matlab help for more info about it.
If you start Matlab script within VEE, it needs a lot of time the first time it starts. But if the matlab engine is running, you will notice a fast access.
So the trick is to start the matlab engine in the beginning of your program.
detlef
_____
Gesendet: Mittwoch, 10. September 2008 15:28
An: VRF
Betreff: [vrf] Mathlab not displayed in preferences and very slow
im using Vee 8.5 and everything is installed what i can select during installation which includes Mathlab.
When i open vee and look in File + Default Preferences + Mathlab, then there is displayed "No Mathlab installed on your machine".
But Mathlab-functions which i created under Vee 6.1 are still working (but very slow) for example the interpolate-function.
In vee 6.1 there was always an extra window shown in taskbar when running a mathlab-function.
Is this new in Vee 8.5?
Why is the version not shown in preferences?
Why is the matlab-function so slow?
Thanks for any help
best regards
Jochen
You are currently subscribed to vrf as: Detlef.Baranski@pilkington.de
Der Inhalt dieser E-Mail (inkl. aller Anlagen) ist vertraulich und ausschließlich für den Adressaten bestimmt. Jede Art der Verbreitung, Nutzung oder Vervielfältigung ist untersagt. Sollten Sie diese E-Mail irrtümlich erhalten haben, informieren Sie bitte sofort den Absender und löschen die E-Mail.
Unternehmensangaben der Gesellschaften mit Sitz in Deutschland:
Pilkington Holding GmbH, Haydnstraße 19, 45884 Gelsenkirchen
Sitz: Gelsenkirchen, Amtsgericht Gelsenkirchen HRB 8997
Geschäftsführung: Dr. Clemens Miller (Vorsitz), Jochen Settelmayer, Thomas Kretschmann, Robert Hales
Vorsitzender des Aufsichtsrates: Dr. Axel Wiesener
Pilkington Deutschland AG, Haydnstraße 19, 45884 Gelsenkirchen
Sitz: Gelsenkirchen, Amtsgericht Gelsenkirchen HRB 2707
Vorstand: Dr. Clemens Miller, Jochen Settelmayer
Pilkington Automotive Deutschland GmbH, Otto-Seeling-Straße 7, 58455 Witten
Sitz: Witten, Amtsgericht Bochum HRB 8443
Geschäftsführung: Thomas Kretschmann
Vorsitzender des Aufsichtsrates: Jochen Settelmayer
Bauglasindustrie GmbH, Hüttenstraße 33, 66839 Schmelz / Saar
Sitz: Schmelz / Saar, Amtsgericht Saarbrücken HRB 52020
Geschäftsführung: Manfred Ebbers
You are currently subscribed to vrf as: j.gallmayer@lxinstruments.com
You are currently subscribed to vrf as: hua_jing@agilent.com
Jochen
_____
An: VRF
detlef
_____
_____
detlef
_____
_____
An: VRF
detlef
_____
An: VRF
Thanks for any help
best regards
Jochen
detlef
_____
An: VRF
Thanks for any help
best regards
Jochen
