The LNF mode is turned on during the adjustment of the instrument, which is the Low Noise Floor Gain Adjust.
I did find a scpi command that controls the condition which is :diag:bloc:lnf:auto on. You won’t be able to see any effect on the screen, but I believe the latches in the instrument are set to this LNF mode on condition.
Thanks! I am developing an automated verification procedure and I noticed that the Test Data from Agilent tests the Harmonics with LNF ON and OFF. The Programming manual did not reference the command for it though. Thanks again.
Regards -
