> Guidelines, suggestions anything
> more in depth than the docs in VEE help.
Get rid of anything that starts with #.
All functions need to be either stdcall or cdecl. VEE won't do fastcall or thiscall. If the public API does not include something like:
#ifdef __cplusplus
extern "C" {
<stuff>
#endif
Then you might have to create a proxy dll to call the functions.
Any typedefs must be accounted for by other means. Simple types can be translated to VEE's types by using the type table:
http://www.vrfarchive.com/vrf_archive/CProgramming101.htm#refTypeTable
Oops, web is down (duh!) Type Table:
VEE Type C Type Data Size Comments
UInt8 char 1 Byte Not usable over the CFI.
Int16 short 2 Bytes Sometimes called a word.
Int32 long 4 Bytes Sometimes called a double word.
Real32 float 4 Bytes
Real64 double 8 Bytes
Text char* 4 Bytes See note 1.
(none) int 4 Bytes? See note 2.
Don't fret about unsigned. Some Windows types you'll see:
Name Type Size Comments
DWORD unsigned long 4 Bytes Four bytes is called a Double Word.
INT int 4 Bytes Just an alias for int.
UINT unsigned int 4 Bytes
LONG long 4 Bytes Just an alias for long.
BOOL int 4 Bytes Boolean, Yes or No, True or False.
BYTE unsigned char 1 Byte
WORD unsigned short 2 Bytes Two bytes is called a Word.
FLOAT float 4 Bytes Just an alias for float.
LPFLOAT float* 4 Bytes Pointer to FLOAT.
LPBOOL int* 4 Bytes Pointer to BOOL.
LPBYTE unsigned char* 4 Bytes Pointer to BYTE.
LPINT int* 4 Bytes Pointer to INT.
LPWORD unsigned short* 4 Bytes Pointer to WORD.
LPLONG long* 4 Bytes Pointer to LONG.
LPDWORD unsigned long* 4 Bytes Pointer to DWORD.
LPVOID void* 4 Bytes Pointer to any type (see next section)..
UINT_PTR unsigned int 4 Bytes Used for "polymorphic types".
ULONG_PTR unsigned long 4 Bytes Used for "polymorphic types".
WPARAM unsigned int 4 Bytes Used to be "word param", used in messages.
LPARAM long 4 Bytes "Long param", used in messages.
LRESULT long 4 Bytes "Long result".
HANDLE void* 4 Bytes "Handle" to object.
LPTSTR char* 4 Bytes Pointer to string, i.e. VEE Text var.
Compound types can usually be stuffed into VEE arrays. Sometimes you wind up using GlobalAlloc & dereferencing actual memory (not usually though).
There are a bunch of general guidelines through out C Programming 101 and Windows Programming 101. These documents will be accessible as soon as I finish maintenance (should be pretty soon now). If you run into really horrendous compound types, Type Spoofin' For Dummies will show you how to do almost anything.
-SHAWN-
#ifdef __cplusplus
extern "C" {
<stuff>
#endif
-SHAWN-
