vrf Help with doing neural network using VEE 8.5 student version
Question asked by VRFuser on Sep 18, 2008
Latest reply on Sep 18, 2008 by VRFuser
Amrik,
I don’t have Excel on my Vee machine, but I believe using the Excel Library with VEE you have to change
    Application.ActiveWindow.Visible = True
to
            xlApp.ActiveWindow.Visible = True
I presume you’ve tried that.
I tend to use Excel’s Object browser in Excel’s VBA Script Editor to find what I can do with Macros in Excel.  So if those commands don’t work, I’d look under Chart and ChartObject using the object browser.
A quick look revealed
Chart.Visible=True
Chart(“Chart1”).SizeWithWindow = True
ChartObject.Visible=True
And
With Charts("Chart1")
    .RightAngleAxes = True
    .AutoScaling = True
End With
Cheers,
Gary
  _____
Sent: Wednesday, 17 September 2008 9:09 PM
To: VRF
Subject: RE: [vrf] Charts in Excel not visible
Hi Gary
Thanks for the info but i have already tried these commands with no affect.
Any other suggestions gladly accepted
Cheers
Amrik
  _____
From: Voltz, Gary [mailto:gary.voltz@AirservicesAustralia.com]
Sent: 17 September 2008 02:28
To: Amrik Sekhon; VRF
Amrik,
Below are 2 Excel Macro Commands that might help.
   ' This forces the Active Window to be visible.
    ' Zoom value in percent
    ActiveWindow.Zoom = 100
I know that there is another one that forces Excel to Maximise too.
Cheers,
Gary
Gary Voltz
SASTO4
Test Equipment and Maintenance and Calibration Centre
Facilities Management Services
Technology and Asset Services
Airservices Australia
E-mail: gary.voltz@airservicesaustralia.com
  _____
Ph 1300 301 120       (within Australia)
Ph +61 7 3866 3382  (outside Australia)
Fax +61 7 3866 3531
HYPERLINK "http://www.airservicesaustralia.com/"www.airservicesaustralia.com
CAUTION: This e-mail is confidential. If you are not the intended
recipient, you must not disclose or use the information contained
in it. If you have received this e-mail in error, please tell us
immediately by return e-mail and delete the document.
Airservices Australia does not represent, warrant or guarantee
that the integrity of this communication is free of errors, virus
or interference.
  _____
Sent: Tuesday, 16 September 2008 10:17 PM
To: VRF
Subject: [vrf] Charts in Excel not visible
Hi All
When i create a chart in excel as a new sheet it is not visible or sometimes it is fomatted so that only the title is visible at about 30pt font size. I have tried to resize using drag of the mouse as well as the options in the view menu on the toolbar. However if i create the chart as an object on the sheet the formating is fine,alas i prefer not to do this since i have 6 graphs to display and i would prefer to have them as individual sheets.
I have a series of data points and i use macros in excel to create the charts. On my laptop they work fine and the formating is correct but on the test machine they are all messed up. I have attached pics of how the chart should look like (good) and bad charts for XL 03/07 as generated by my test machine.
I am using win XP SP2, I have tried using XL2003 and 2007 with differing results. I have tried this on 3 different machines and only one is problematic which also happens to be the main test machine, doh.
I have searched the archive and there is no info on this, so any pointers or help appreciated.
I can send my XL file to anyone should they require it.
Cheers
Amrik
You are currently subscribed to vrf as: gary.voltz@airservicesaustralia.com
No virus found in this incoming message.
Checked by AVG - http://www.avg.com
Version: 8.0.169 / Virus Database: 270.6.21/1674 - Release Date: 16/09/2008 08:15
You are currently subscribed to vrf as: hua_jing@agilent.com
